5508 WLC with LAG enabled
Slim32195
Community Member
I enabled Lag on a 5508 controller.  Now all the port numbers say 13.  I thought they were supposed to be 29.  Does this mean LAG isn't configured corecctly?  Also how do you test to see that the LAG group is working correctly between the 6509 and WLC?
Stephen Rodriguez
I'm the 5508 the lag port is 13 in the 4402 it shows as 29. The easiest way to test the lag is to shut down a port on the switch and make sure the traffic continues to flow
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
