5520 controller initial configuration
Not applicable
is there a config guide for the 5520.
i am going through the initial CLI commands and it is different than the 5508.
how do you respond the Mulitcast prompt if you are just using Unicast?
Leo Laohoo
Just enter a multicast IP address, like 224.0.0.1, and change it back to unicast.
Not applicable
it didn't like that address, but i tried 239.0.0.1 and it worked. i was then able to change it to unicast.
Thanks a bunch!!
