5520 wireless controller
JMCNEL
Level 3
Level 3
Are the 2 x 10 gigabit Ethernet ports backward compatible to 1 gigabit Ethernet for the interim until we can replace our 6509e with a 9407R?
Switching Between 10 G and 1 G
  • If there is nothing installed in port 1, the board will be configured for 10 G mode by default. Therefore, to switch to 1 G mode, an SFP module must be installed in port 1 and the system needs to be rebooted.
  • Conversely, if an SFP module is installed and the user wants to switch to 4 x 10 G mode, then an SFP+ module must be installed in port 1 and the WLC rebooted.
  • Thus, Online Insertion and Removal (OIR) of SFP and SFP+ between 10 G and 1 G is not possible.
  • OIR of 10 G to 10 G and 1 G and 1 G is possible."
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-1/5520-WLC-DG/b_Cisco-5520-WLC-deployment-guide.html
-If I helped you somehow, please, rate it as useful.-
