5760 WLC Features
NICOL DUNLOP
Frequent Visitor
Frequent Visitor
The release notes for the new 5760 WLC mention that "profiling and on boarding" are not yet supported.
http://www.cisco.com/en/US/docs/wireless/controller/3.2_0_se/release_notes/OL28115_3_2_se_rn.html
Does this mean that when using ISE with Guest Server features, device profiling or guest self registration isn't supported ??
Ravi Singh
Level 11
Level 11
Yes It is true that 5760 does not support "profiling and on boarding". But when you use ISE for the same it will support the entire feature which you looking for.
