5GHz SSID Cisco aircap 3702I issue
berto1886
Hi to every ones who will read me, I've a speed problem with the 5GHz interface of a Cisco aricap 3702I, if I connect to it with an Android smartphone the connection speed is set to 433Mbps then, if I connect to the same SSID with a notebook (dual band 802.11ac) after an initial notice from windows of a non crypted network connection it connect at 54Mbps! The same notebook connected to a Netgear AP it connect up to 868Mbps! I post the configuration below, tell me if and where is the problem please. Thank'you
no service pad
service timestamps debug datetime msec localtime show-timezone year
service timestamps log datetime msec localtime show-timezone year
service password-encryption
hostname AP
logging buffered 10000
logging rate-limit console 9
no logging console
enable secret
no aaa new-model
clock timezone ITALY 1 0
clock summer-time ITALY recurring last Sun Mar 2:00 last Sun Oct 2:00
led display off
no ip source-route
ip routing
ip cef
no ip domain lookup
ip domain name domain.it
dot11 mbssid
dot11 pause-time 100
dot11 syslog
dot11 vlan-name dati vlan 10
dot11 vlan-name servizi vlan 50
dot11 ssid AP_Dati
vlan 10
authentication open
authentication key-management wpa version 2
mbssid guest-mode
wpa-psk ascii
dot11 ssid AP_Dati_5
vlan 10
authentication open
mbssid guest-mode
wpa-psk ascii
dot11 ssid AP_Service
vlan 50
authentication open
mbssid guest-mode
wpa-psk ascii
power inline negotiation prestandard source
no ipv6 cef
username Cisco password cisco
bridge irb
interface Dot11Radio0
description Interfaccia fisica Radio 2.4GHz
no ip address
encryption vlan 10 mode ciphers aes-ccm tkip
encryption vlan 50 mode ciphers aes-ccm tkip
ssid AP_Dati
ssid AP_Service
antenna gain 0
stbc
channel 2412
station-role root
interface Dot11Radio0.10
description Interfaccia Radio AP_Dati
encapsulation dot1Q 10 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.50
description Interfaccia Radio AP_Service
encapsulation dot1Q 50
bridge-group 50
bridge-group 50 subscriber-loop-control
bridge-group 50 spanning-disabled
bridge-group 50 block-unknown-source
no bridge-group 50 source-learning
no bridge-group 50 unicast-flooding
interface Dot11Radio1
description Interfaccia fisica Radio 5GHz
no ip address
ssid AP_Dati_5
antenna gain 0
peakdetect
no dfs band block
stbc
channel width 80
channel 5180
station-role root
interface Dot11Radio1.10
description Interfaccia Radio AP_Dati_5
bridge-group 1
interface GigabitEthernet0
no ip address
duplex auto
speed auto
interface GigabitEthernet0.10
description Interfaccia VLAN 10 Dati
bridge-group 1
interface GigabitEthernet0.50
description Interfaccia VLAN 50 Servizi
bridge-group 50
interface BVI1
description Interfaccia bridge di gestione
mac-address 00a2.ee2d.907c
ip address 192.168.0.252 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.0.254
ip ssh version 2
bridge 1 route ip
line con 0
login local
line vty 0 4
login local
transport input ssh
sntp server 193.204.114.232
end
Rasika Nayanajith
I would try without TKIP encryption. With TKIP you are limited to 54Mbps max data rate. With AES, you can go for 802.11n/802.11ac higher data rates.
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Rasika
Great! It works! Thank'you!
Good to hear that.
Rasika
