600 OEAP maximum users
Craig Le-Butt
Level 4
Level 4
We currently use a Sophos Red for Secure VPN for small locations.
I'm looking as using a 600 OEAP instead on a 5508 and putting a 3750 switch in.
I've read it can only support up to 15 connsecutive users at one time, just want to clarify is this just on the wireless or 15 devices on the box including an deivces connecting via a switch.
Cheers
Sandeep Choudhary
HI Craig,
As per my knowledge it is just for wireless.
Only fifteen users are allowed to connect on the WLAN on the 600 series at any one time. A sixteenth user cannot authenticate until one of the first clients de-authenticates or a timeout occurred on the controller.
If there are fifteen users on one of the WLANs, no users will be able to join the other WLAN on the 600 series at that time. This limit does not apply to the local private WLANs that the end user configures on the 600 series designed for personal use and clients connected on these private WLANs or on the wired ports do not affect these limits.
***They also support 4 wired clients per Remote LAN using port.
Dont forget to rate helpful posts
