11-05-2014 04:47 PM - edited 07-05-2021 01:53 AM
I also posted this in IP Telephony. Not sure which section is more appropriate for my problem, but I really need help here.
I have an odd problem.
I have a 7921, which registers as it should in an CUCME 8.6 environment.
4 ephones, (3) 7975G and (1) 7921. One incoming / outgoing pots line. No voip.
My problem:
calls made from the 7921 to internal extensions work perfectly. Audio in both directions.
Calls made from the 7975's to internal extensions and to external numbers via pots (VIC2-2FXO) work perfectly - audio in both directions.
Calls made from the 7921 to external numbers via pots, however, have no outgoing audio. Inbound audio works fine.
Any ideas? Config is attached
11-05-2014 08:49 PM
11-06-2014 06:02 PM
This turned out to be a NAT issue. It has been resolved.
