7925G EAP-FAST connection failed
Jason Aarons
Level 10
Level 10
4.0.217.0
Everything works great with a Lenovo T61 laptop running EAP-FAST using the IBM Access Connections client.
However a new out of box 7925G SCCP 1.3(3) phone shows "connection failed" onscreen to WLC 4.0.217.0 and ACS 5.1
Here is what the RADIUS log on Cisco Secure ACS 5.1 shows, TAC verified the ACS is good.
11001  Received RADIUS Access-Request
11017  RADIUS created a new session
Evaluating Service Selection Policy
15004  Matched rule
15012  Selected Access Service - 7925s
11507  Extracted EAP-Response/Identity
12100  Prepared EAP-Request proposing EAP-FAST with challenge
11006  Returned RADIUS Access-Challenge
11018  RADIUS is re-using an existing session
12102  Extracted EAP-Response containing EAP-FAST challenge-response and accepting EAP-FAST as negotiated 12800  Extracted first TLS record; TLS handshake started.
12805  Extracted TLS ClientHello message.
12806  Prepared TLS ServerHello message.
12808  Prepared TLS ServerKeyExchange message.
12810  Prepared TLS ServerDone message.
12105  Prepared EAP-Request with another EAP-FAST challenge
5411  EAP session timed out
4DigitCCIE
Level 5
Level 5
Did you change the eap timeout to a higher value?  I know this is for a 7921, but I believe that the 7925 has the same issue.
"config advanced eap request-timeout 20"
http://www.cisco.com/en/US/docs/solutions/Enterprise/Mobility/vowlan/41dg/vowlan_ch10.html#wp1048186
John
