08-12-2013 12:20 PM - edited 07-04-2021 12:38 AM
Looking for some guidence on what to check next:
I used the following procedure, trying to connect to a 7925G via USB to configure the wireless profile:
Step 1 To setup the USB LAN connection, do one of the following:
• For Windows XP—Click Start > Settings > Control Panel > Network Connections.
• For Windows 2000—Click Start > Settings > Control Panel > Network and Connections.
Step 2 Locate and double-click the new LAN connection to open the Local Area Connection Status window,
then click Properties.
Step 3 Scroll to the Internet Protocol (TCP/IP) section and click Properties.
4-3
Cisco Unified Wireless IP Phone 7925G Administration Guide for Cisco Unified Communications Manager 7.0(1)
OL-15984-01
Setting Up Your PC to Configure the Phones
Step 4 In the Internet Protocol (TCP/IP) Properties window, choose Use the following IP address:
Step 5 In the IP address field, enter a static IP address for the PC: 192.168.1. (1 through 254 except 100), for
example: 192.168.1.11
Note • By default, the Cisco Unified Wireless IP Phone 7925G is configured with 192.168.1.100 so you
cannot use this IP address for the PC.
• Make sure to use an IP address that is not in use on any other interface on the PC.
Step 6 Enter the subnet mask: 255.255.255.0
Step 7 Click OK to make the changes.
I am using an XP computer with IE8 with no other LAN connections enable expect the NIC and the Cisco USB Network interface. I can ping the IP of the phone, 192.168.1.100, from my workstation. However I am unable to open the web page for the phone via IE8 using the address https://192.168.1.100. The cisco usb NIC appears to be active and enabled, and functioning otherwise, under network connections. Is there some borwser setting I need to check?
08-12-2013 03:13 PM
Well good question. I can share with you that when i need to web into the phone I need to enable phone personalization in the call manager.
__________________________________________________________________________________________
"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
08-12-2013 03:17 PM
Thank you. I should have explained that this is a brand new phone out of the box, which has never been configured in our CM. I am only attemtpting to modify the SSID, key, and other settings so that the phone can be registered with CM.
08-12-2013 03:19 PM
Should not need to do that as Personalization is for wallpaper and ringtone provisioning.
You just need to ensure that web access is set to read-only or full in the CUCM inside the 792x phone config.
Is defaulted to read-only by default, but if it is disabled which sounds like the case here, then you will be able to ping the phone but not browse to the phone via https.
If that is not the issue, then there is an issue with your browser or is not allowing the cert to be pushed down to estabilish the https connection.
08-12-2013 04:41 PM
Thanks Mike .. What was I thinking .. It's been a while ..
08-12-2013 03:20 PM
Oddly it doesnt mention about the personaliztion (which I stated) ..
Maybe Mike can chime in ..
