8.1MR3 Beta Availability
Javier Contreras
8.1.123.x Available - 8.1MR3 Beta
Beta process is closed, final release 8.1.131.0 is now posted in CCO
Support
For any new issue during this test, please write to wnbu-mrbeta@external.cisco.com, pre-existing problems would be directed through normal TAC support channels, the image is TAC supported until CCO release of final code
Image types
AS_5500* can be used for Wism2/2500/5508 controller types. Not 5520
AS_7500* can be used for 7500/8500/5520
AS_CTVM can be used for vWLC
ap1g4-ME can be used for AP 1850 Mobility Express
This release is exclusively bug fixes
Issues fixed in this release
8.1.123.20
CSCuv92719    vWLC crash on 8.1.111.0 serving the RF dashboard web page
CSCuw29419    Cisco Wireless LAN Controller Radius Packet of Disconnect Vulnerability
CSCuu68490    duplicate radius-acct update message sent while roaming
CSCuv44568    Downloading RADIUS AVP via GUI does not load Vendor IDs correctly.
8.1.123.16
CSCuu86587    DN1/DN2: Need closed loop Niagara/Cavium fan control
CSCuv72545    Mobility Express Controller takes a long time to come up in Day 0 mode
CSCuw48570    ME UI: Apply button in creating WLAN is not working
CSCtu45614     Spectrum Management Bit Should be set to 1 all the time
CSCuw30799    Kernel panic at IPReassembler on internal AP , while pre-image download
CSCuw47234    ME: Transfer upload datatype coredump broken
CSCus53495     DFS detection due to broadcom spurious emissions 2700/3700
CSCut98006     DFS detections due to high energy profile signature on 2600/3600
CSCuu34220    Observed traceback in wlc doing rogue test.
CSCuv43057    ME wlc crash on ConfigSynctoAp
CSCuv74590    Please delay reboot if image upgrade is in progress
CSCuv88543    ME-UI]: U/P with special characters under Admin acc GUI Kicks off.
CSCuw37896    Corsica 8.2 MR2 M.E. AP cert date is newer than controller build date
CSCuw38455    sanity: corsica ap1832 unable to detect rogue ap
CSCuw41770    ME: HTTP download through web UI
8.1.123.12
CSCur71315     1552 bridge Transmit voice queue stuck
CSCuq79283    Sanity-Beni: ap1142n 1042n 1140 traceback dot11_set_frame_templates
CSCus61679     Problem in Client Stats Reports - Follow up CDETS
CSCut07170     AP1532 WGB intermittently doesn't see incoming probe responses
CSCut33114     LAG with 1G does not work in 5520 and 8540
CSCut83422     vwlc SN changed after mgmt interface ip change
CSCuu05565    NDP packets not tx'ed on secondary20 channels
CSCuu32049    WGB attempts to send IAPP change channel event during scanning
CSCuu37437    WLC8510 crashing while NMSP polling in progress.
CSCuu54100    Switching between SSIDs fails with FAST SSID enabled on PMIPv6 WLANs
CSCuu72366    WLC 5508 Silent Crash 8.0.110.11 mmListen process
CSCuu82416    Evaluation of wlc for OpenSSL June 2015
CSCuu85603    flex+MeshAP shw's Incorrct chnnel Info in O/P 'sh mesh convergence' list
CSCuu86265    Flex AP Local switching WLAN specific losing VLAN Mapping Configuration
CSCuu98667    vWLC: Low Scale VM auto reboots while downloading image -2GB default Mem
CSCuv00107    PMIPv6 Client MAC Address shows up on the mac address table of Switch
CSCuv00598    Optimized Roaming per WLAN feature
CSCuv00856    CleanAir process fails to start for 1572 AP when using 169
CSCuv28555    3702 - Voice Queue stuck
CSCuv34946    EOGRE and PMIPv6 client fails to move to Run state
CSCuv37613    Apple devices failing 802.11r FT roam
CSCuv47241    5500 WLC crashed with SNMP walk on 8.2.1.43
CSCuv47679    EoGRE client traffic packet with DF bit set is getting fragmented
CSCuv48219    SCTG ST:Module doesnot come up after AP reboot in Centralised mode
CSCuv51521    Active WLC should send GARPs when HA Re-Paring after Active-Active state
CSCuv54337    ME: "Error while opening a file" before switchdrvr bootup
CSCuv57159    ME: MC2UC conversion not happening
CSCuv61883    Error message to be corrected for error popped up(a generic issue)
CSCuv62540    Adding -S domain support for Hong Kong
CSCuv63073    ME: Confusing msg when next-preferred-master is the current Master AP
CSCuv74068    AP3700 low throughput with 3700 WGB 40mhz
CSCuv80866    CMEB-52 WLAN Security 'WPA2 Personal' has WPA AES policy enabled
CSCuv81907    ME: Show time has garbage on NTP auth status
CSCuv83856    Read/Write user is unable to edit settings from GUI
CSCuv86624    ME: HTTPs Day-1 GUI connection presents WebAuth cert instead of WebAdmin
CSCuv87657    8.0/8.1 WLC's fail to send FRAMED-IP attribute to AAA server
CSCuv90042    Fastlocate distant clients have strong rssi value from AP intermittently
CSCuv90508    Wlan Count: Deleting last wlan does not update wlan count
CSCuv90567    ME: Changing controller country code does not update Internal AP
CSCuv90769    Unable to schedule pre-image download for 12 - 12.30PM
CSCuv92645    SNMP walk on clsDownloadFileType returns invalid enum for ME controller
CSCuv93732    Hyperlocation not working after adding WLC to CMX
CSCuv96344    ME: WLC crash files shouldn't be in /storage/cores
CSCuv97538    Mu-beamformee field in VHT Cap IE is enabled in assoc resp
CSCuw02126    HALO:  Last digit of NTP server is dropped when address has 12 digits
CSCuw02922    show rules is empty for mobility express controller
CSCuw04344    Module doesnot come up after AP reboot in Centralised mode on AP3700
CSCuw13898    RLAN client drops from the WLC when b radio Admin status get disturbed
CSCuw16735    ME emWeb Crash
CSCuw19551    ME : show time not shown as "AUTH SUCESS" when NTP Sync happens
CSCuw22214    11v shows 'not supported' under client detail for 11v capable client
17 Replies 17
Hi Charles
Currently targeting this Friday for posting, stay tuned
regards
Not today I guess.  No!  Wait!!  There it is!!   HALO here I come!
hi
Code is now posted in CCO, enjoy!
regards
