05-17-2012 12:51 PM - edited 07-03-2021 10:10 PM
Can anyone confirm if any of the 800 series routers support wireless station-mode repeater?
The software configuration guide suggests it is possible but I've been unable to find a definitive answer.
Thanks.
Solved! Go to Solution.
05-18-2012 01:25 AM
Please Check the following:
Please make sure to rate correct answer
05-18-2012 01:25 AM
05-21-2012 01:32 AM
Many Thanks.
Typical, it isn't supported on any of the devices I have to play with.
