Maximum active SSID's on WLC5500
yzeledon
Hi all,
I have a question regarding to the maximmum number of active SSID's on a WLC 5500 with 3500i, it;s my understanding that the 3500i can support 16 active SSID's is it the same when connected to the WLC? Also, if possible would the WLC shutdown un-used Radios or maybe afterhours?
Cheers,
Yanil
Stephen Rodriguez
All AP can support up to 16 concurrent SSID to be configured on them.  With the WLC I believe you can have 192 WLAN and distribute those via AP groups.
Currently the WLC can't automagically shut down the radios that are unused, or on a timer.
What you can do, however, is from WCS push a config template based on time that will shutdown the WLAN you have configured.
If you don't have WCS, you can use a time based acl on the switch to block UDP 5246/5247 to the WLC during the hours you are 'closed'.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
