802.11a New Tx Power level is: 0 Reason: DTPC Tx Power value: 0 dbm
amrou-hattab
Hello
i have recently purchased new ap model 9105AXI to replace some AP 1815i , so i have updated the VWLC to the version 8.10.196.0
since this upgrade i have noticed that client are disconnecting randomly when connecting to both model 9105axi or 1815 . im trying to figure out the root cause of this behavior
 20:45:34 2024RF Manager updated TxPower for AP xx Base Radio MAC: xx and Radio Type: 802.11bg New Tx Power level is: 0 Reason: DTPC with Max Tx Power value: 0 dbm
9Tue Oct 8 20:45:34 2024RF Manager updated TxPower for AP Base Radio MAC: xx and Radio Type: 802.11a New Tx Power level is: 0 Reason: DTPC Tx Power value: 0 dbm
 - It would indeed be better , to have a deployment with all the same AP models ;  you can also
   debug clients (disconnecting or not) ; using
            WLC # debug client <MAC ADDRESS>
  Client debugs can be analyzed with : Wireless Debug Analyzer
  You can stop that or all debugging on the controller using : debug disable-all
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
5 Replies 5
Mark Elsen
 - Have a checkup of the WLC's configuration using : WirelessAnalyzer input (procedure) for AireOs controllers
                                                     and feed the output from that into Wireless Config Analyzer
  M.
       Beauty and terror
      Just keep going
       No feeling is final
thanks a lot for the feedback , based on the analayser i dont have errors related to RF parameters . im wondering if a mixed wireless envirement with 1815i 802.11ac with 9105ax 802.ax capability could cause issue , as issues started after upgrading the vwlc version  , and intlalling 9105ax ap . i think that i have to custom channels configuration , to make config adequat for both models .
  M.
       Beauty and terror
      Just keep going
       No feeling is final
amrou-hattab
regulatory domain.
Thanks a lot for the idea of the Analyser
I have question please is there a way how make policy to change all access point from local to flex connect mode even for access point that i will add in the future.
By assigning a properly configured site tag, APs can be automatically converted to FlexConnect mode.
Auto-Convert APs to FlexConnect Mode
When you assign a site tag that includes a Flex profile, the AP will automatically convert to FlexConnect mode without any user intervention.
So, every new AP which joins the controller have to get this site tag (Statically/Regex).
In older AirOS controllers (e.g., 8510, 5520, and 8540), this could be done using the CLI command:
(Cisco Controller) >config ap autoconvert
Jagan Chowdam
/**Pls rate useful responses**/
