802.11b and Nortel Companion phone system
fcapra
It appears the Nortel phone system operates at 1.92gHz range. It seems like there should be enough separation between the freqs, but has anybody installed the two systems side by side? any problems or issues?
smahbub
Level 6
Level 6
This works well in a lab environment, though deployments are relatively rare.
blue.modal
Doesn't that system max out at two handsets per controller? Shouldn't be hard to position an upgrade.
