802.11g Windows 2000 problems, please help!!
admin_2
Level 7
Level 7
I am having problems using 802.11g client adapter on a windows 2000 enviroment it has to do with when domain authentication occurs in the startup
The main problem is:
Its almost like the Cisco utility isnt running as a service and/or the card isnt initializing on boot like the older 802.11b only cards did
Does anyone have a fix for that or a workaround?
rmiles
Level 4
Level 4
I am having problems with these new cards too. The TAC says its this bug CSCee01822 and that a new client is due the second week in May. We'll see if that really fixes it.
Not applicable
Cisco has sent me the new driver that fixes this problem and now its working properly.
Was the driver they sent you a beta version?
Not applicable
Is there any chance you can send me the driver?
