09-23-2014 10:04 AM - edited 07-05-2021 01:35 AM
Hi everyone
just a clarification about Fast Transition for me:
Following environment: WiSMv2 with 7.4.121, al lot of 1240 APs, over 200x 7921/7925 WLAN Phones and few iPhone 5s / 5c with 7.1 iOS.
The environment work very well for Cisco 792x Phones.
Now the Customer would like to use Jabber on iPhone therefore I create a new SSID for the iPhone and configured it with Fast Transition option.
According to the Enterprise Best Practice for Apple Mobile guide I have to enable the “Over-the-Distribution System” because I user AP 1240
also the old generation.
Further I must enable following over the CLI (options are not available over the GUI):
config wlan assisted-roaming neighbor-list enable
config wlan assisted-roaming dual-list disable
config wlan assisted-roaming prediction enable
Is this the correct approach ?
Marco
Solved! Go to Solution.
09-23-2014 06:14 PM
Hi Marco,
you described enabling FT (802.11r) & AP assisted Roaming (802.11k) in the above. Here about some details about how those work.
1. 802.11r FT Association
2. 802.11r Over-the-Air FT
3. 802.11r Over-the-DS FT
4. 802.11k AP Assisted Roaming
I would enable one at a time (802.11r or 802.11k) & see the behavior of these jabber clients when roaming.
Rasika
*** Pls rate all useful responses ***
09-23-2014 06:14 PM
Hi Marco,
Rasika
09-23-2014 06:14 PM
Hi Rasika,
I have already configured 802.11r Over-the-Air but customer report roaming issue.
I will try 802.11r Over-the-DS and later enable also 802.11k
Marco
