802.1x authentication with ACS 4.1 for MAC OSX
I simply wanted to know if it's possible to have 802.1x authentication with MAC OSx on ACS Plateform 4.1?
If yes, what pre-required on ACS and MAC OSx? Methods of authentification which are recommended ?
I'm sorry, but i don't find documents which show validated test on 802.1x implementation method on ACS 4.1 with MAC OSx supplicant.
Thanks in advance
Best regards
carenas123
Level 5
Level 5
Make sure that Mac OS operating system supports the following 802.1X authentication type:
EAP-Cisco Wireless (or LEAP).
Yes, Refer to the below DOC
http://support.apple.com/kb/HT2717
Port settings and ACS configuration remain the same as you do it for windows based clients
