802.1x Machine Authentication without AD
dan.letkeman
Level 7
Level 7
I'm new to 802.1x security, and i'm wondering if it's possible to do windows machine authentication without an active directory?
Dan.
Tiago Antunes
Windows Machine authentication requires machine credentials, and these credentials can only exist on the AD.
What you can do is authenticate the machine using its MAC address (Mac authentication bypass), and for this you only need to configure mab on the switch, make sure the client do not speak dot1x and create the user with username/password = mac address on the RADIUS server.
HTH,
Tiago
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
