851W wireless routing issue
steve
Community Member
I've been running a small office with an 851W wireless router for over a year without issue. However, recently I have been having intermittent (every couple days) issues with the wireless. Specifically, connections via wireless can no longer route out or see other machines on the LAN. Wired connections continue to work fine. Also, you can still get a dhcp address via wireless, but as I mentioned, there seems to be a problem resolving internal and external addresses. I've scanned for other networks causing interference, but that doesn't seem likely as the only other networks in range are on different channels. Wondering if this might be a hardware problem with the router/radio. Any thoughts would be greatly appreciated. Thanks in advance.
vmoopeung
Level 11
Level 11
You may try setting the channel to 2412 or "Current Frequency: 2412 Mhz Channel 1".
