861-W wireless network setup
jsteffenwac
Community Member
I am using Cisco Configuration Professional 2.2 to set up an 861-W router. When I add a wireless network and configure the wireless LAN to a wired VLAN that has a DHCP pool, do I need to do anything further to get the wireless LAN to hand out the DHCP addresses from the pool? The wireless LAN is broadcasting and I am able to connect. But no IP address is aquired. Thanks.
0 Replies 0
