876w roaming problems
m.holfeld
Frequent Visitor
Frequent Visitor
We have one cisco876w router and three access-points. We are using a wpa eap authentication. Roamin between the access-points only works fine. Roaming from one access-point to the cisco876w works fine. But roamin from the 876w to a access-point fail.
The client stay connected in the 876w. The client lost the wlan connection and connects to an access-point.
But on the router you can see that the client is always connected to the router. On the access-point we can see that the client can?t get a ip address but he is connected to the ap.
Where can be the problem?
Sincerely,
Martin
larrywoods
From my experience with the 876W and even the wireless module that goes into an 1800 or 2800 ISR, these wireless APs DO NOT do roaming and are assumed to be use for small/home office environments. Essentially, since you are using EAP, this adds more latency on the authentication process. Everytime a client, connects to an AP, it will go through that process. If the client roams around and trys to connect to the 876W as closest node on the WLAN, it would then have to reauthenticate because the 876W thinks it is the only AP on the LAN.
With the other APs, I assume they are IOS APs. Just make sure you have WDS configured and the WDS Manager will then act as the "key manager" and knows of the other wireless APs on the LAN. This guarantees a 150ms roam and manages clients more efficiently.
Again, to my knowledge, the 876W or any wireless module in an ISR router, is NOT capable or roaming.
