877W - problem
okenobi
i have a problem with 877w.
i have some pc's connected to the fast interfaces and dsl is up and running.
pc's can surf ( via nat on the dialer interface ).
now , on the wireless part , i configured auth (mac address) and enc + dhcp pool + nat on the dhcp pool.
i am connected with my pc to the router by wireless and got an ip , i can ping the router dot1radio ip address but not outside to the internet.
ping from the router it self - with source ip of the dot1radio address is working so NAT is good.
what am i missing ? do i need briding ?
thanks
andrew.black
Community Member
Bridging ---yes, sample config below
bridge irb
interface Dot11Radio0
no ip address
encryption mode ciphers tkip
ssid xxxx
authentication open
authentication key-management wpa
wpa-psk ascii 0 xxxxxxxxxxxxxxxxx
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address ---now in bvi1
ip tcp adjust-mss 1400
bridge-group 1
interface BVI1
description Local lan
bandwidth 10000000
ip address ---
ip directed-broadcast
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly
ip route-cache flow
bridge 1 protocol ieee
bridge 1 route ip
