88MR1 Interim/Beta Build Availability
pbaragur
We are pleased to announce the fourth 88MR1 Interim/Beta (8.8.114.48) for production deployment.
Base Code: 8.8.100.0
First Beta Build: 8.8.104.40
Latest Beta Build: 8.8.114.48 (8.8MR1 Interim/Beta Release 3rd Refresh.)
Note:
1. Release 8.8MR1(8.8.114.48 or 8.8.104.84 or 8.8.104.84 or 8.8.104.40) Interim is supported by TAC for all features and          hardware models introduced with CCO Release 8.8.100.0.
    Any features or hardware models introduced on this new MR1 release, are specifically supported by Cisco Engineering
   (wnbu-escalation@cisco.com)
2. Please make sure to update your browser with latest Aspera Client to be able to download the files.
    https://downloads.asperasoft.com/en/downloads/8?list
3. Platforms not supported in this release.
     5500/2500/Wism2/7510/8510 WLC Platforms are not supported from 8.6 onwards itself due to planned EOL.
     Below AP models are not supported from 8.6 onwards itself.
  • AP1600
  • AP3500, AP1260
  • AP2600, AP3600
  • AP801
  • AP802
  • AP1550
Following are the new features introduced in 8.8MR1(that are not TAC supported until CCO):
  • iCAP(Intelligent Capture)
  • Sensors
  • DNAC Support with Ver 1.2.5
  • WGB on COS Aps
  • IPSK Flex mode P2P blocking
  • L3 reauth for Panasonic
  • Open DNS on ME
  • ME Exands
Access Request :  http://cs.co/88MR1InterimAccess
(Within 24 hours automatic access to software download will be given)
Software Image Download : http://cs.co/88MR1ImageRepository
[NOTE: Please make sure to use Aspera Client to download files, if downloading for the first time from shares.cisco.com you will be prompted to install Aspera Client on top of Website]
Feedback Form : http://cs.co/88MR1Feedback
8.8.114.48
Bug Description
CSCvj71373    Ping command does not use management interface as source interface
CSCvk61078    VLAN priority tag inside the EoGRE packet set to non-zero when 802.1p set to none in LOCAL mode
CSCvk62680    Cisco WiSM2 not releasing licenses after reboot
CSCvk73639    WLC to support OUI based Client Profiling
CSCvm10519   Intergrated Management Module (IMM) summary shows a username, which is multiple usernames
CSCvm15625   DCA channel assignment on XOR radio is broken while static 5G assignment
CSCvm34641   WLC is sending packets out to Gateway with DF = 1 when inside header is set DF = 0 - EoGRE
CSCvm37510   Controller crashing due to SNMP memory corruption
CSCvm62202   1852 Kernel Panic at ClientCapabilitiesTracker
CSCvm65360   WLC redirects to internal webauth login page after successful external webauth login
CSCvm71487   2800 /3800 AP dropping the Neighbor Advertisement for Global Ipv6 address
CSCvm97915   WLC includes  NULL Bytes within the JSON it posts
CSCvn00564    iCAP: with Partial Packet Capture, all the retried packets are having the original packet timestamp
CSCvm54906   capwapd crashes due to two capwapd instances
CSCvk43025    Local Split and Central path traffic stops after some time with Cisco 2800 APs
CSCvk70185    WLC Smart License : Smart license registration failing for ProductInstance not valid in switchover
CSCvm04408   Cheetah WGB - Fast Roaming PSK with/without over the DS. FT Auth-Response is not received
8.8.104.84
CSCvk35047    WLC stops working when LAG mode is enabled on the AP
CSCvm46823 DNAC Wireless Assurance does not respond to POST causing WLC to timeout & eventually drop data
8.8.104.79
CSCvi04556    SSO failover causes mobilty tunnels go down
CSCvj01739    Cisco WiSM2 unexpectedly reloads on task name sshpmLscTask after initial config
CSCvj06837    MAP Wave 1 AP mesh security failures after roaming between 2 parents
CSCvj47460    WiSM2 crash on SNMP task
CSCvj72136    Barbados AP (2800/3800) loses its default gateway reachability
CSCvj72766    UX AP:Primed UX AP reset to UX when SNTP server is configured
CSCvk05150    OpenDNS profile keeps being mapped for client when the username changes
CSCvk15043    Wave 1 APs - AP radio FW image install failure in the bootup loop
CSCvk15068    IOS APs, recovery logic for MD5 checksum failure on primary Image
CSCvk24360    WLC power supply status is incorrect when there is no power supply
CSCvk26519    Cisco 1562 MAP stops sending Block ACK once the Cisco 1572 RAP moves to another controller
CSCvk26563    Cisco 1810W AP running 8.2.170.4 code: 5G radio FW resets @0x009A4F9F
CSCvk41512    APX800 sniffer mode not sending frames with AMSDU 1500 Bytes to destination
CSCvk44959    WLC crash on Taskname 'emWeb'
CSCvk51634    Wave 2 Flex Efficient Upgrade fails as Master AP sends empty image_str to WLC
CSCvk55651    AP1852 failure of association due to set CAPWAP tunnel failed
CSCvk59498    Cisco 3702 AP: High CPU utilization under NCI Rx.  Unable to join the controller
CSCvk62355    AP2800 running ME image 8.6.101.0, 8.7.106.0 crash in ewsContexSendRedirect200->ewaDate
CSCvk76043    SS-P2:Unable to Associate clients with PSK/dot1x security in Flexconnect Standalone Mode.
CSCvm00214   WiSM2 memory leak due to hotspot_anqp
CSCvm05695   AAA override for native VLAN with flexlocal switching not applied to client on Cisco 1562 AP
CSCvm21666   Cisco 4800 series AP takes pre-download of unsupported code
CSCvm25082   EoGRE clients ARP Response inside CAPWAP gets corrupted
CSCvm26277   RLAN multicast does not work with local mode local switch - 1815w
CSCvm32197   WLC crash on webauth_redirect_main task
CSCvm43028   8.8MR1:Number of DX messages in sync Queue ... 440001[805520.362884] Controller crashed ....Queue
CSCvm46810   WLC System Crash in Dot1x_NW_MsgTask_7 due to validateWpaKeyStateSTART
CSCut85555    APF_HA-3-SYNC_RETRANSMIT_FAIL Messages in show msglog
CSCvg76166    Channel utilization changes to 0% on Marvell chipset based Cisco Wave 1 APs
CSCvi82147    Failed to set Country Codes when WLC has redundant country codes CA2, KR, PH2, US2, USL, USX
CSCvi92170    Cisco 1800 series APs falsely shows 100% channel utilization on 5GHz
CSCvj08387    WLC stopped working on spamApTask6
CSCvj23106    RX-SOP global configuration not applied to new Access Points
CSCvj60609    vWLC Webauth not working
CSCvj65449    AIR-AP1562D-E-K9 with regulatory domain Kazakhstan does not join the WLC
CSCvj70604    Mesh APs MAP Best-Effort tx queue stuck
CSCvj73077    Cisco 1810W APs may have power denied from older POE 802.3af switches
CSCvj86238    WLC stops working as emWeb spikes to 100% CPU usage after executing "show run-config"
CSCvk00884    The WLC is replying with the wrong value for the following OID: bsnAPIfProfileParamAssignment
CSCvk02153    Wave 1 AP WLAN Client Stats cldcClientDataRetries counter is zero
CSCvk09513    AP is not downloading the WLC 85Mr3 image rather it says image is already in the backup
CSCvk18752    Cisco 1815AP: Incorrect VCI string of DHCP option 60
CSCvk23577    Client is unable to connect due to the "Failed to create a timer" error
CSCvk25593    Cisco 1542, 1815I APs - Ethernet interface flapping when connected to 100Mbit switchports
CSCvk36463    Support Bundle output only genertaes WSA core bundle when WSA is enabled
CSCvk41249    WLC 8.7 doesn't present full certificate chain on webauth guest portal
CSCvk56651    BSSID/Client Rate Limit prevent clients to pass traffic on Mobility Express
CSCvk62055    Cisco Wave 2 APs Preimage download fails after 64 retries with poor WAN link
CSCvk72075    WLC is sending incorrect counter value for the broadcast and multicast throgh SNMP
CSCvm04245   Cisco 1810W AP reports low power after requesting and receiving 14.2W after upgrading to 8.5.131.0
CSCvg80634    WLC msglogs flooded with DNS-3-GETADDRINFO_SUCCESS every 10mins with DNS for NTP
8.8.104.40
CSCvk59498    AP3702 High CPU Utilization under NCI Rx.  Unable to join WLC
CSCvh87451    Cisco 1832 AP Rx not working with AP not responding to probe requests
CSCvi51536    Access Point is not sending TCP fragments over the air
CSCvk26519    1562 MAP stops sending Block ACK once the 1572 RAP moves to another WLC
CSCvk26563    AP1810W 5G radio FW assert @0x009A4F9F  8.2.170.4
CSCvk62055    COS AP Preimage download fails after 64 retries with poor WAN link
CSCvk63215    Cisco 1852 series APs Kernel Panic due to NSS memory corruption
CSCvk63459    3802, 4800 AP drops packets larger than 1426 (inner IP) with VxLAN
CSCvm04245   1810W AP reports low power after requesting and receiving 14.2W after upgrading to 8.5.131.0
CSCvi25532    Standby 8540 WLC-reloads unexpectedly with rmgrMain due to IPC timeout
CSCvi85834    New Mobility CAPWAP control keepalive should not plumb keys when receiving unencrypted responses
CSCvi90766    Cisco AP with regulatory domain Morocco cannot join the Cisco WLC
CSCvj39005    Wireless Clients losing L2VNID override when performing Switchover on Cisco 5520 WLC
CSCvj47445    Cisco WLC sending CAPWAP discovery response when it has no available licenses
CSCvj99694    WLC 5520: 8.8 Beta - SNMPTask systemCrash 8.8.1.149
CSCvk15165    Cisco Controller reloads unexpectedly after modifying SNMP trap controls via GUI
CSCvk20484    IPC timeout and tracebacks reported on HA pair running 8.5.131.0 (8.5MR3)
CSCvk22312    hotspot2 OSU SSID is picking profile name
CSCvk23577    Client is unable to connect due to "Failed to create a timer"
CSCvk25644    WLC HA standby reboots reaching maintenance mode due to missing NaServCaCert_p12.pem on Active
CSCvk27093    NAS-ID in WLAN cannot be changed in the startup-command after you saved once
CSCvk39948    WLC is not returning the expected prompt when logging in via SSH
CSCvk41068    Advance IPMI is not set and causing fan noise
CSCvk53883    ME GUI: preauth ACL rules disappear if VLAN tagging is enabled on WLAN
0 Replies 0
