9105axw-b EWC Conversion
PatrickMorgan
TL/DR:
9105axw-b
Problem 1 – How do I make space?
Problem 2 – Am I copying the file correctly?
I received a Catalyst 9105axw-b intending to use the 9800 Embedded Wireless Controller.   After reading several documents and watching the 9100 series videos, I was confident that I could convert the device.  Most of the documentation is aimed towards the other 9100 series devices and have directions with unacceptable commands, like config t.
I am having a difficult time getting the access point to allow me to tftp the IOS bin file.  Below is part of the show version output:
cisco C9105AXW-B ARMv7 Processor rev 5 (v7l) with 950528/456128K bytes of memory.
Processor board ID FGL2442L8DD
AP Running Image     : 8.10.130.0
Primary Boot Image   : 8.10.130.0
Backup Boot Image    : 8.10.130.0
Primary Boot Image Hash:
Backup  Boot Image Hash:
4 Multigigabit Ethernet interfaces
2 802.11 Radios
Radio Driver version : Broadcom BCA: 17.18 RC2.0
Radio FW version : 24203.103.r40354 0
NSS FW version : NA
Base ethernet MAC Address
Part Number                          : 0-000000-00
PCA Assembly Number                  : 074-123371-01
PCA Revision Number                  : 01
PCB Serial Number                    :
Top Assembly Part Number             : 074-123371-01
Top Assembly Serial Number           :
Top Revision Number                  : A0
Product/Model Number                 : C9105AXW-B
I have attempted several methods.  copy source dest doesn’t work in this IOS.-
  1. ap-type mobility-express tftp://192.168.1.245/9105/ap1g8 tftp://192.168.1.245/9105/C9800-AP-iosxe-wlc.bin
    This outputs a long string of blank lines with sporadic hyphen characters followed by invalid input detected.
  1. ap-type mobility-express tftp://192.168.1.245/9105/C9800-AP-iosxe-wlc.bin
    Output:
    39.9%
    curl: (23) Error
    transfer command failed (Error 23)
  2. archive download-sw /no-reload tftp://192.168.1.245/9105/C9800-AP-iosxe-wlc.bin
    Output:
    39.9%
    curl: (23) Error
    Image transfer failed
  3. Attempted u-boot xmodem with baud of 38400 ---- took too long
I am making an assumption that the device is running out of space.  I cannot seem to find the commands to delete, as it is handcuffed to what can be deleted and I am having trouble viewing the files.  Clearly my /tmp is 100% full (fixes with reload).  But I would like to have enough space to download and use the image.
show filesystems
Filesystem                Size      Used Available Use% Mounted on
devtmpfs                462.4M      4.0K    462.4M   0% /dev
/sysroot                                464.1M    129.8M    334.3M  28% /
tmpfs                     1.0M     44.0K    980.0K   4% /dev/shm
tmpfs                   464.1M         0    464.1M   0% /run
tmpfs                   464.1M         0    464.1M   0% /sys/fs/cgroup
/dev/ubivol/part1       171.3M     54.5M    116.7M  32% /part1
/dev/ubivol/part2       258.9M     56.1M    202.8M  22% /part2
none                    100.0M    100.0M     48.0K 100% /tmp
none                     10.0M         0     10.0M   0% /firmwarelog
none                      1.0M     44.0K    980.0K   4% /dev/shm
Any assistance would be welcome.
30 Replies 30
marce1000,
With all due respect, it's either a bug in the software or 3 different documents below are incorrect...  Please let me know which you believe it is?  Bug or documents are wrong?
See Table 1 (Last line) (https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/nb-o6-embded-wrls-cont-ds-cte-en.html)
See Table 3 (2nd to last line) https://www.cisco.com/c/en/us/td/docs/wireless/controller/ewc/17-4/rel-notes/ewc-rn-17-4-x.html
See Table 7 (specifies "9105axW") https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
                                               > It is correct that the EWC for the 9105AXWis supported
  You are confused . this ap is only supported as a client in an EWC based environment, it can not run the controller. My original reply referencing AP's that support EWC still stands.
 M.
Marce1000, I don't think you carefully read in my post, I wrote in bold parenthesis on the first line > "(client only)"<  You still need the iOS XE image to join the EWController, otherwise, why would the software image be available for that platform?? see below.  There must be some way to upgrade it??  Also, all the links that I included in my post point to where it's supported in that software image.  Can you be kind enough and let us know how to upgrade it?
-sam
I have had this done by a Cisco tech on one ow my 3 ap's wish I remembered how he did it. I would like to move 1 to another location
cisco C9105AXI-E ARMv7 Processor rev 5 (v7l) with 1989872/1305524K bytes of memory.
Backup Boot Image : 0.0.0.0
1 Multigigabit Ethernet interfaces
2 802.11 Radios
APMYHW.MYHW.MYHW#logging console disable
APMYHW.MYHW.MYHW#archive download-sw /no-reload sftp://8.8.8.8/home/cisco/ap1g8
Starting download AP image sftp://8.8.8.8/home/cisco/ap1g8 ...
It may take a few minutes. If longer, please abort command, check network and try again.
Please enter SFTP credentials ...
Username: cisco
######################################################################## 100.0%
Upgrading ...
upgrade.sh: Script called with args:[NO_UPGRADE]
do NO_UPGRADE, part1 is active part
upgrade.sh: Script called with args:[-c PREDOWNLOAD]
do PREDOWNLOAD, part1 is active part
upgrade.sh: Start doing upgrade arg1=PREDOWNLOAD arg2=,from_cli arg3= ...
upgrade.sh: Using image /tmp/cli_part.tar on ax-bcm32 ...
Image signing verify success.
[2/19/2021 14:28:40] : Shadow is now in-synced with master
[2/19/2021 14:28:40] : Verifying against bundle image btldr.img...
shared_printenv updated
upgrade.sh: part to upgrade is part2
upgrade.sh: AP version1: part2 , img 17.4.1.6
upgrade.sh: Untar /tmp/cli_part.tar to /bootpart/part2...
upgrade.sh: Sync image to disk...
upgrade.sh: AP version2: part2 17.4.1.6, img 17.4.1.6
upgrade.sh: AP backup version: 17.4.1.6
upgrade.sh: Finished upgrade task.
upgrade.sh: Cleanup for do_upgrade...
upgrade.sh: /tmp/upgrade_in_progress cleaned
upgrade.sh: Cleanup tmp files ...
upgrade.sh: Script called with args:[ACTIVATE]
do ACTIVATE, part1 is active part
upgrade.sh: activate part2, set BOOT to part2
upgrade.sh: AP primary version after reload: 17.4.1.6
upgrade.sh: AP backup version after reload: 8.10.130.0
Successfully setup AP image.
Archive done.
APMYHW.MYHW.MYHW#reload
APMYHW.MYHW.MYHW#sh ver
cisco C9105AXI-E ARMv7 Processor rev 5 (v7l) with 1989868/1287352K bytes of memory.
AP Running Image : 17.4.1.6
Primary Boot Image : 17.4.1.6
Primary Boot Image Hash: edc5b332acc64e7d4e01655bb1e26d7a9bdf7606b656bfe7b1ba6733a0259274cc202d60073408553eb871a5f76efb120c2f49e3fe3d0f2d1104c64fe085a7fd
2 802.11 Radios
AND !!!!
APMYHW.MYHW.MYHW#ap-type ewc-ap sftp://8.8.8.8/home/cisco/ap1g8 sftp://8.8.8.8/home/cisco/C9800-AP-iosxe-wlc.bin
VERY HELPFUL!! THAT WAS IT!!!
Thank you for the command that I couldn't find listed anywhere and no one believed that this AP can join an EWC environment!
Best to you!!
First, many thanks for this explanation
It seemed to work for me, but ...
I'm using C9105AXW-E as AP to convert in EWC
I see in your explanation you use an AP : C9105AXI-E
Is there a limitation with my version of AP ? W instead of I
I don't have as much storage as you have in your own AP. And i see that @PatrickMorgan  had the same one. I don't know if it worked for him ^^
i downloaded the archive to the AP, extracted, installed, everything seemed to be fine
cisco C9105AXW-E ARMv7 Processor rev 5 (v7l) with 950524/426028K bytes of memory.
Processor board ID PSZ25361KRF
AP Running Image : 17.7.1.11
Primary Boot Image : 17.7.1.11
But :
APE44E.2D12.1C94#ap-type ?
capwap Switch to CAPWAP AP type
workgroup-bridge Switch to Workgroup Bridge(WGB) AP type
Thanks for your help,
David
The last command still give me the error
curl: (23) Error
AP1#ap-type ewc-ap tftp://192.168.88.252/C9800-AP-iosxe-wlc.bin
% Invalid input detected at '^' marker.
can not get past this command
Hi! does it accept well referenced command?
regarding your last command: APMYHW.MYHW.MYHW#ap-type ewc-ap sftp://8.8.8.8/home/cisco/ap1g8 sftp://8.8.8.8/home/cisco/C9800-AP-iosxe-wlc.bin
Getting result:
cap1#ap-type ewc-ap sftp://10.81.3.100/ap1g8 sftp://10.83.3.100/C9800-AP-iosxe-wlc.bin
Starting download eWLC image sftp://10.83.3.100/C9800-AP-iosxe-wlc.bin ...
Username: cisco
Password:
transfer command failed (Error 7)
cap1#
error 7,
my version is same to yours:
cisco C9105AXI-E ARMv7 Processor rev 5 (v7l) with 1989868/1274964K bytes of memory.
tftp fails as well:
ap1#ap-type ewc-ap tftp://10.81.3.100/ap1g8 tftp://10.83.3.100/C9800-AP-iosxe-wlc.bin
Starting download eWLC image tftp://10.83.3.100/C9800-AP-iosxe-wlc.bin ...
-=O=-                                                  #    #    #   #
curl: (28) Error
%Error opening tftp://10.83.3.100/C9800-AP-iosxe-wlc.bin (Error 28:  Operation timeout)
cap1#
SammyB
Patrick,
SystemEngineer32313 posted the solution, I tried it and it worked!
Sammy! so just to clarify again:
C9105AXI-E doesn't work as controller, but it does work as client for other EWC?
rniu
I also faced this issue, and the solution won't fully resolved my issue, here is my resolution:
there is a bug https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvu22886 , if you are using a version which is older that 17.3.4c you can not upgrade to newer version, use command mentioned by DDSD in previous post to update the AP to 17.3.4 rather than 17.9.x (for example), then you won't face transfer command failed (Error 23) error.
upgrade path https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-8/release-notes/rn-17-8-9800.html#Cisco_Concept.dita_59a2987f-2633-4630-8c7b-a8e8aecdeaf7
Rniu,
just to clarify again: C9105AXI-E doesn't work as controller, but it does work as client for other EWC?
fuadirmawan
Nice Tutorial,,i have try  and its works thanks Master PatrickMorgan
