9115 supporting CleanAir or not?
i_mohamed
Does Cisco 9115 support CleanAir or not?
2 Accepted Solutions
Scott Fella
You can find this info by doing some searching or looking at the data sheet.  Here is a matrix that you can reference for that feature and many others.
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/feature-matrix/ap-feature-matrix.html#_Toc118737959
-Scott
@ammahend
it dose not support clearair, although it does support spectrum intelligence, which is not cleanair but a much more toned down version of what cleanair can do for interference avoidance, more details here
Thanks a lot for that clarification !
Best regards
7 Replies 7
M02@rt37
[Edited]
Hello @i_mohamed
No, c9115 Series Access Points do not support CleanAir technology.
On 9100 access points series with the RF ASIC, the access point can perform advanced RF spectrum analysis and delivers features such as Cisco CleanAir.
Best regards
The 9115 doesn’t have the Cisco RF ASIC. From the Wi-Fi 6 APs, the 9120 and 9130 has.
ammahend
-hope this helps-
@ammahend
Best regards
you are welcome
-hope this helps-
Leo Laohoo
Frankly, I would not be investing in the 911x, 912x or 9130 because EoS announcement is imminent.
The replacement for the "first gen" will be the 913x.
Scott Fella
-Scott
