9800-L-F: APs will not register
perrymcgrew
I have had case open for about a month on this and at least 3 different TAC engineers.   I have 9800L-F set up in HA-SSO (RP+RMI).  We have tried 17.9.x, 17.10,1 and now are on 17.11.1.
I have set the AP Mgt as VLAN 2 (10.0.0.0 /22) and the 9800L Management Interface at 10.0.3.253.  I have 3560X switch set up in my office "lab" with 3 APs (two 9115AXi and 1 2802i) connected as well as the Primary 9800L chassis.   The APs will not connect -- or if they do, it takes days.  We have done numerous traces / debugs / packet captures and TAC still cannot explain why.   I am hoping a fresh set of eyes can see what the problem is and how to fix.
The AP console session repeats this:
[*04/19/2023 14:36:12.8578] CAPWAP State: Discovery
[*04/19/2023 14:36:12.8808] Discovery Request sent to 10.0.3.253, discovery type STATIC_CONFIG(1)
[*04/19/2023 14:36:12.8818] Discovery Request sent to 10.0.3.253, discovery type STATIC_CONFIG(1)
[*04/19/2023 14:36:12.8828] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*04/19/2023 14:36:12.9098] Discovery Response from 10.0.3.253
[*04/19/2023 14:36:22.2708] Started wait dtls timer (60 sec)
[*04/19/2023 14:36:22.2778]
[*04/19/2023 14:36:22.2778] CAPWAP State: DTLS Setup
[*04/19/2023 14:36:37.3428] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: DTLS Setup(3).
[*04/19/2023 14:37:19.3018] OOBImageDnld: OOBImageDownloadTimer expired for image download..
[*04/19/2023 14:37:19.3018] OOBImageDnld: Do common error handler for OOB image download..
[*04/19/2023 14:37:19.3288]
[*04/19/2023 14:37:19.3288] CAPWAP State: DTLS Teardown
[*04/19/2023 14:37:19.3778] OOBImageDnld: Do common error handler for OOB image download..
[*04/19/2023 14:37:19.4628] status 'upgrade.sh: Script called with args:[CANCEL]'
[*04/19/2023 14:37:19.5058] do CANCEL, part1 is active part
[*04/19/2023 14:37:19.5228] status 'upgrade.sh: Cleanup tmp files ...'
[*04/19/2023 14:37:19.5488] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: DTLS Teardown(4).
[*04/19/2023 14:37:24.0528] OOBImageDnld: OOBImageDownloadTimer expired for image download..
[*04/19/2023 14:37:24.0528] OOBImageDnld: Do common error handler for OOB image download..
[*04/19/2023 14:37:24.0728] No more AP manager addresses remain..
[*04/19/2023 14:37:24.0728] No valid AP manager found for controller 'CUN-WLC-9800LF' (ip: 10.0.3.253)
[*04/19/2023 14:37:24.0728] Failed to join controller CUN-WLC-9800LF.
[*04/19/2023 14:37:24.0728] Failed to join controller.
(TAC set a static IP on this AP of 10.0.2.1 /22 for a test.  The other test APs use DHCP and have the same console messages)
The core where VLAN 2 is defined:
ip dhcp pool 9800_WLC_MGT
network 10.0.0.0 255.255.252.0
default-router 10.0.3.254
domain-name xxxxx.yyy
option 43 hex f104.0a00.03fd
dns-server 192.168.8.1 192.168.8.2
interface Vlan2
description 9800-WiFi_Mgt Subnet
ip address 10.0.3.254 255.255.252.0
no ip redirects
no ip unreachables
no ip proxy-arp
The 9800L Interfaces:
interface Port-channel10
description WLC AP MGMT PORTS
switchport mode trunk
interface TenGigabitEthernet0/1/0
no negotiation auto
channel-group 10 mode on
service-policy output AutoQos-4.0-wlan-Port-Output-Policy
interface TenGigabitEthernet0/1/1
no negotiation auto
CUN-WLC-9800LF#show wireless interface summ
Wireless Interface Summary
Interface Name Interface Type VLAN ID IP Address IP Netmask          NAT-IP  Address MAC Address
Vlan2      Management                  2      10.0.3.253     255.255.252.0 0.0.0.0  8c1e.xxxx.yyyy
CUN-WLC-9800LF#show wireless management trustpoint
Trustpoint Name : ewlc-tp1
Certificate Info : Available
Certificate Type : SSC
Certificate Hash : 9a80a68f45b442770a4567d4xxxxxxxxxxxxxx
Private key Info : Available
FIPS suitability : Not Applicable
The 3560X switch that the 3 APs and Primary 9800L are connected to:
description ** EtherChan to CUN-WLC-9800LF **
spanning-tree portfast edge trunk
interface GigabitEthernet0/47
description CUN-WLC-9800LF LAG
interface GigabitEthernet0/48
The AP connected ports:
interface GigabitEthernet0/1
description ** TEST AP PORTS **
switchport access vlan 2
switchport mode access
There is no VLAN pruning in place on trunk ports.
TIA - Perry
37 Replies 37
Scott Fella
I have a 9800-L-C in my home lab using two 10G in LAG.  The only difference is that I setup the management vlan as native vlan.  Might as well give that a try and make sure your switch has the native vlan defined:
switchport trunk native vlan 2
negotiation auto
negotiation auto
-Scott
I actually had the Native VLAN 2 specified on the Port-Channels and the Interfaces on the 9800L and the 3560X switch.  The current TAC Sr Engineer on the case had me remove them.  It has not helped at all.
Scott Fella
Why are you not using the Gigabit ports?  The fiber is for 10gig... just noticed that.  You probably should try using these interfaces.
interface TwoGigabitEthernet0/0/0
interface TwoGigabitEthernet0/0/1
If the ports are not auto negotiating, that can be your issue using those ports.  Here is the recommended SFP's also:
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/datasheet-c78-742434.html#SFPssupported
-Scott
The SFP's are Cisco GLC-TE and are listed as supported.  TAC has not stated that I can't use the Te0/1/0 & Te0/1/1 with 1 Gig Copper.  The 3560X in my office does not support 10G.   When I do move the 9800L to the datacenter, it will be connected to 2 Te Ports in our 4500X L3 switch.
Use the gigabit ports since you are not connecting it to a 4500x. What you need to validate is if that is the issue or not. You should really start with basic config and even only using 1 port.  Then build it up and see when it breaks. You are also only testing with one controller right?
What I would do since this has been an issue for a while is to wipe the controllers, only use one and just configure the basics for network connectivity.  Use only one gigabit port and just see if the ap joins or not.  Then I would do the same for the other controller.  This eliminates any issue with one or the other and gives you a good starting point.  Also pick a code that you will use in production.  Only once you get the ap's joined, is when you can go ahead and make small changes and or setup SSO if that is what you will be implementing.
-Scott
Leo Laohoo
Has the AP been factory-reset?
Yes.   The APs have been factory reset as one of the tests.  This AP's show ver displays:  AP Running Image : 17.11.0.155 which matches the 9800L 17.11.1
I'm going to suggest downgrading to 17.9.3 and see if makes any difference.
We upgraded to 17.9.3, then upgraded to 17.10.1 and then 17.11.1 per troubleshooting recommendation.
It is counter-productive to use Early Deployment (ED) releases like 17.10.1 or 17.11.1.
No idea what was in TAC's mindset to recommend upgrading to ED just to troubleshoot AP joining issue.
I would strongly recommend re-queuing the case to EMEA or NAM/LATAM.
17.11.1 provided some debugging enhancements.  Probably not fair to say it was an official Cisco TAC suggestion -- more like trying to see if we may be hitting a new bug.  We have had the same problems on all releases, including 17.9.3.  I have asked current TAC if we should revert back from 17.11.1 and so far has not said we should need to do that.
If this was the recommendation provided by TAC, I'd be reaching for the phone and getting the case re-queued to EMEA or NAM/LATAM.  If the case goes back to the same TAC "zone", get it requeued to anywhere else but the same TAC zone.
I am suspect TAC is "taking you for a ride" and playing games.
I just factory reset a 9115AXi.   Console output attached.   Does not resolve the issue.
         >...I just factory reset a 9115AXi.   Console output attached.   Does not resolve the issue.
 I was wondering if there is full capwap connectivity from the access points subnet to the controller , put  a machine with nmap installed in that subnet and try :     nmap -sU -p5246-5247    controller-hostname
 M.
