9800-L-F WLC SSL Certificate Signed Using Weak Hashing Algorithm
lightda
Hi Comminity,
I have an issue here with WLC 9800-L-F.
I use Nessus to scan WLC, it found a High level issue: SSL Certificate Signed Using Weak Hashing Algorithm
It seems like I hit a bug of Sweet32: https://bst.cisco.com/quickview/bug/CSCvv09676
After checking, the SSL certificate which hit this issue was for Web-Admin use.
I've tried to search the way to fix it, but could not found, did anyone done this before?
Should I generate a new certificate with SHA-256?
no ip http secure-server is not in the options.
Rich R
@shambhu.kumar that config is for SSH not HTTPS!
What version of software are you using @lightda
Refer to the TAC recommended code versions link below.
See:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/technical-reference/c9800-best-practices.html#Dealingwithtrustpoints
https://mrncciew.com/2023/09/11/9800-web-admin-certs/
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-12/config-guide/b_wl_17_12_cg/m_web_admin_settings.html
https://www.youtube.com/watch?v=BbVi9OYaBjU
shambhu.kumar
Try this and re-scan, It will not detect vulnerability like, Deprecated SSH Cryptographic Settings or SSH Prefix Truncation Vulnerability (Terrapin)
ip ssh server algorithm mac hmac-sha2-256 hmac-sha2-512
ip ssh server algorithm encryption aes256-ctr
ip ssh server algorithm kex ecdh-sha2-nistp521
ip ssh server algorithm hostkey rsa-sha2-512 rsa-sha2-256
ip ssh server algorithm authentication keyboard
Rich R
See:
Thanks for helping, it was useful,
My co-worker have open TAC Case to confirm the step, sharing step to otherelse:
#This will disable GUI access to the WLC – This will not affect anyone trying to authenticate to the SSID
no ip http server
#This will create an RSA key called RSA-WLC-SSC
crypto key generate rsa label RSA-WLC-SSC modulus 2048
#This will create the trustpoint called WLC-SSC and give it the following configurations
  • Stronger Hash
  • Create it as a self signed certificate
  • Does not perform any revocation checks
  • Links the RSA key that we created above
crypto pki trustpoint WLC-SSC
hash sha256
enrollment selfsigned
revocation-check none
rsakeypair RSA-WLC-SSC
exit
#This will now apply the newly created trustpoint onto the WLC
crypto pki enroll WLC-SSC
yes
no
no
yes
#This will now configure the new trustpoint for web admin and enable GUI access
ip http secure-trustpoint WLC-SSC
ip http server
