9800 WLC AAA-override flex SSID, client exclusion - SSID FAILURE
mqontt
Hi Guys,
i'm testing out the 9800 wlc (17.9.3version) with 9120 AP.
I created AAA-override WLAN (ISE pushes vlan id to point the client to right vlan - using flex profile and mapping the vlan names to vlan numbers).
However when client tries to connect to this SSID it is not able to associate.
I ran debugs and i can see (also on ISE) that client goes through dot1x authentication phase and it seems to succeed, since i can see access-accept with proper attribute (vlan name) coming from the ISE to the WLC.
However the client is always put into exclusion list, with the reason "Service Set ID failure" . Which i have never seen before, nor have i clue what could it mean.
Does anyone have any idea what to look out for ?
SANET_AUTHZ_FAILURE - Service Set ID Failure, username CN=CLIENTCERT.LOCAL.DOMAIN, audit session id DEFCA8C00000007FE68ED912
[088e.90e3.abd4:capwap_90000004] Authz failed/unapplied), method: dot1x. Signal switch PI.
%SESSION_MGR-5-FAIL: R0/0: wncd: Authorization failed or unapplied for client (088e.90e3.abd4) on Interface capwap_90000004 AuditSessionID DEFCA8C00000007FE68ED912. Failure Reason: Service Set ID Failure.
%CLIENT_EXCLUSION_SERVER-5-ADD_TO_EXCLUSIONLIST_REASON_DYNAMIC: R0/0: wncmgrd: Client MAC: 088e.90e3.abd4 was added to exclusion list associated with AP Name:APAC4A-56BE-B784, BSSID:MAC: 045f.b91e.f96e, reason:Service Set ID failure
                             - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwb20613
    Also have a checkup review of the 9800 wlc configuration with the CLI command show tech wireless ; have the output analyzed with  https://cway.cisco.com/wireless-config-analyzer
 M.
6 Replies 6
 Service Set ID (SSID) seems to be related to the WLAN.  Is there any SSID ID attached to the ISE rule?
Yes there is a condition on that policy: "Radius Called-Station-ID" ENDS_WITH ssidname
its strange that this works normally on 5520.
i was wondering if this could maybe have something to do with fact that i didnt delete the previous client authentications from ISE when they were connected to AP that is on 5520 controller.
this is in the debugs as well:
in the debugs i can see this as well:
[sanet-shim-translate] [21213]: (ERR): 088e.90e3.abd4 : Policy resolution failure in sanet, code = 24, Service Set ID Failure
policy resolution failure in Sanet would mean that the ISE was not able to resolve the policy?
docjb0221
You might need to make sure ISE isn't trying to use a dACL. I believe dACLs in flexconnect mode are not supported on the 9800s. See https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-10/config-guide/b_wl_17_10_cg/m_dACL.html.
for this SSID we do not have dACLs configured. However we have it for some other SSID
But if i create them manually on WLC and push them to the AP via Flex Profile then they should work, right ?
 M.
Bingo!
this is most likely what im encountering.
Since the policy set has result Authorization profile with 2 different cisco-av-pair ssid sent in access-accept
wouldn't have thought that this could be causing issues.
thanks a lot!
