AAA and AP 1240Ag
dgerbergss
I currently use secure ACS 4.1 and I wanted to know if I could use tis with my 1240AG AP. I am looking to be able to use AAA to log into the Access Point.
Can this be done? Will iot be the same set up as a router or does it need something special?
andrew.prince
Level 10
Level 10
Yes it can be done - I have only done it on a 1131AG AP running IOS in a test lab, but if you AP is running IOS then I presume it's the same.
I used the following config example in a test lab:-
http://www.cisco.com/en/US/customer/tech/tk722/tk809/technologies_configuration_example09186a008069593c.shtml
HTH.
