AC Power Adapter for C9120AXI Access Point
dweav6716
Can someone tell me which AC power adapter is needed to power up a C9120AXI access point?
I want to power the AP up without using a POE switch.
Scott Fella
You can look this up I. The data sheet also. Here is what the data sheet states:
Input power requirements
● 802.3at Power over Ethernet Plus (PoE+), 802.3bt Cisco Universal PoE (Cisco UPOE+, Cisco UPOE ®)
● Cisco power injector, AIR-PWRINJ6=
● 802.3af PoE
● Cisco power injector, AIR-PWRINJ5= (Note: This injector supports only 802.3af)
-Scott
Leo Laohoo
What exactly are you looking for? A power brick or a power injector?
I am looking for the specific power brick to be used with a C9120AXI access point.
Not possible.
The AP doesn't support power bricks. The presented interfaces are console port, ethernet port and a USB port. That's it.
The only way to power up the AP is PoE or Power Injector.
