access network share through wireless LAN controller 2504
dominikflamand
Community Member
I'm having trouble accessing a network share from a wireless client through my wireless controller 2504.
I can ping the server where the share is on and also I can ping the default GW firewall.
There's no problem with the share. So I think this is some setting in the wireless LAN controller.
Somebody know wich setting this could be? So that I can access a network share through the wireless controller.
With an unmanaged wifi the network share is perfectly reachable from the client. So It has to be some setting in the controller.
Greetings,
Dominik
Stephen Rodriguez
Two questions, do you have Broadcast forwarding enabled?  Are you using the same subnet on the wire and wireless?
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
No I don't have broadcast enabled. Can I do this on the wireless controller? And yes the wire and wireless are on the same subnet.
But I also see vlan settings for the ports on my wlc.
Port 1: management vlan ==> this one is connected to my switch
Port 3-4: directly connected to my managed AP ==> Wich VLAN should these 2 ports be on?
Greetings,
Dominik
Thanks Steve. I enabled global multicast and broadcast forwarding. My problem seems to be fixed now 🙂
Greetings,
Dominik
blenka
Level 7
Level 7
The broadcast forwarding should be enabled and your vlan ID in the switch and the dynamic interface you create in controller should be same.
