01-25-2016 11:38 PM - edited 07-05-2021 04:32 AM
Guys we have 10 1552 outdoor access points tried to register under WLC
But in-order to change the autonomous a.p to light weight a.p tried to telnet the access point not able to telnet and ssh
While trying to telnet session time out same using ssh
This is not a case with all access point some only
By default telnet is enabled
Can you please help me on this
01-25-2016 11:55 PM
What happens if you plug into their console port?
01-26-2016 12:11 AM
Console port is working am able to login
Whether we have to do some configuration for telnet to be enabled.
01-26-2016 12:12 AM
Why not just convert it to light weight from the console port?
01-26-2016 12:18 AM
We are able to do the same after converting the same will be able to do telnet and ssh
We mounted this access point on pole un mounting is not that much easier
