08-18-2016 03:51 AM - edited 07-05-2021 05:40 AM
Hi Everyone,
An access point has 1Gig port connected to access layer switch on 1Gig port.
How it achieves the 450Mb per user on 5Ghz 802.11ac where 20+ users are connecting.
Beacon
08-18-2016 04:11 AM
You can't achieve such throughput per user. What is the AP model you use.
Even it is 11ac capable AP, total throughput ~600Mbps for the whole AP. So all clients connect to that AP has to share it.
When there is 1 client on that AP, that is the highest throughput a client can achieve.
Rasika
*** Pls rate all useful responses ***
Need to learn WiFi, Please check these out
www.wifitraining.com/about-wifi/ - WiFi Training by WiFi Experts
www.my80211.com - George's Blog
www.mrncciew.com - My Blog
08-18-2016 06:19 AM
Thanks Rasika for your reply.
I'm using AP 3702e and also 3602 model.
Thanks!
