12-25-2016 12:44 PM - edited 07-05-2021 06:16 AM
Hi all,
An access point in my organization is not taking IP address.
From the switch If i give cdp neighbor i am able to see that device is connected.
Switch model : C2960S POE.
AP model : AIR-LAP1141N-A-K9
i have tried changing the access point in same model. but no luck.
i am getting the same issue.
Please help on this.
Surendranath
12-25-2016 01:45 PM
Is DHCP Option 43 enabled or configured correctly?
12-25-2016 05:21 PM
yes.
Actually AP was working fine 2 days ago also in the same switch port.
But after removing from that port and connected to another port in same switch , there it started this issue.
Do you require any logs from my side?
12-25-2016 08:24 PM
Maybe the port configuration is incorrect? The port may have the wrong VLANs or the allowed-VLAN has the wrong VLAN? Maybe the VLAN database doesn't have the correct VLAN.
12-26-2016 08:25 AM
we have a dedicated vlan for wifi access points and it is correctly configured.
the same vlan is allowed in the trunk port also.
but dont know why it is not taking IP.
12-26-2016 10:20 AM
Hi Leo,
right now i have assigned a static IP, and it is working fine now.
dont know what is the exact issue.
