access point and controller
rahman001
Level 5
Level 5
Hi everyone,
I have 17 units of Access Points(AIR-AP1041N-E-K9) and a Wireless LAN Controller(AIR-WLC2125-k9).
I know that these access point are standalone, but can this controller be used with these access point?
If not what can be done to make the controller control all these access point?
please advice?
br
adeola
8 Replies 8
Leo Laohoo
The WLC can work with the WAPs you've mentioned as long as the WAPs are running the correct IOS and the WLC is running 7.X firmware.
To convert the WAPs from autonomous to CAPWAP/LWAP is as simple as copying the lightweight IOS and booting from it.
the IOS in the WAP is below:
S104W7K9-12425JACisco 1040 Series IOS WIRELESS LAN
br
adeola
That's the wrong software.  You need LIGHTWEIGHT IOS.
So what are the procedure that I will use to convert the AP to LAP?
br
To convert the WAPs from autonomous to CAPWAP/LWAP is as simple as copying the lightweight IOS into the WAP and booting from it.
have the LWAPP/CAPWAP recovery image on your tftp server.
The image name should have something like k9w8
on the AP run the following command:
AP#archive download-sw /overwrite /reload tftp://......................
Please make sure to rate correct answers
fbarboza
Level 8
Level 8
To convert the unit fro
IOS to LWAPP you just need to download the LWAPP image to a tftp server and then use the normal ios upgrade procedure with the archive command using the lwapp image instead of the IOS and once the ap reboots it will be in lwapp mode.
