Access-Point going up/down
cisco.kid111
Hello All
We got Issue with One Access Point [ model - AP1242AG ] - it goes up/down.  Users connected on this Access Point get disconnected or time-out connecting to Server. The access-point was installed around 3-4 weeks back. We checked the cable connecting to the Access Point but didnt notice like disconnected or time-out.
[ Access Point was configured with these options ]
AP Name -  JD1
status - Enabled
AP mode - Local
IP address - Static
No of Radio Interface - 2
802.11 b/g/n
802.11 a/n
which debug command will help to identify the issue or GUI option
thanks in advance
Cisco Kid
17 Replies 17
Thank You all
After I restarted the Access Point from the WLC i do not see any issue.
The Access Point is connected using Power Injector - [ donno what triggered to see how AP powered? - help me to understand this ]
thank you
Cisco Kid
I suspect I know.  You confirm that the WAP is powered by an injector.  Your attachment shows the WAP loosing connectivity TO THE WLC without loosing power.
This means that the issue is between the power injector and the switch.  I am suspecting the patch cable from the power injector could be faulty.
Hi leolaohoo
thank you for sharing your point. I would check that as well.
Cisco Kid
