Access Point not showing up in Cisco Prime
nh6we
I have a 3702 access point which is up and running on a 5508 controller running 8.0.121.x code.  The site has Cisco Prime (2.2) running.  Prime sees all of the other 3702 access points but one.  When you check the controller the one problem access point show up as registered and operational.
Any ideas why the one access point is not showing up in Cisco Prime even though it shows up on the 5508 controller as registered and operational?
Rick Ciotti
Curious if you found a solution to this? I have the same issue with one 3702 running prime 3.1. the odd thing is, the AP count between prime and the controller actually match.
