Access point product number and radio question
pietje puk
Hi all,
I was looking at the data sheet of the 3802 access point.
AIR-AP3802E-x-K9
AIR-AP3802E-x-K9C
 AIR-AP3802p-x-K9
AIR-AP3802p-x-K9C
What is the differents between K9 ,  K9c (configurable) and 3802p?
Second question, Is it possible to use internal antenna's in the 3802E? So if we need a antenna later that we can use that one?
thank you
Sandeep Choudhary
AIR-AP3802E-x-K9 -  k9w8 (Normal image) , Access Point with External Antenna
AIR-AP3802E-x-K9C - Mobility Express software image , Access Point with External Antenna
AIR-AP3802p-x-K9 -  k9w8 (Normal image) , Access Point with External Antenna
AIR-AP3802p-x-K9C - Mobility Express software image , Access Point with External Antenna
More info here: http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-3800-series-access-points/datasheet-c78-736498.html
No you cant use internal Antenna, you need to use external Antenna for 3802E AP.
Dont forget to rate helpful posts
Sandeep Choudhary
