Access Point - Radio interfaces admin'd down by default
karkera.rinat
Community Member
This is regarding Access point integration with WLC 5508.
Post downloading the software image from WLC Access points will be configured as per the production environment; however we are observing that the Access points (1620i) by default are having the radio interfaces Admin'd down.
The current software version that we are using on the WLC is: 8.0.121.0.
Rinat S K
7 Replies 7
Leo Laohoo
Post the complete output to the following commands:
1.  WLC:  sh sysinfo;
2.  AP:  sh version;
3.  AP:  sh ip interface brief
1. sh sysinfo (From WLC)
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.0.121.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
Build Type....................................... DATA + WPS
System Name...................................... ######################
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... #######################
IPv6 Address..................................... ::
Last Reset....................................... Software reset
System Up Time................................... 7 days 19 hrs 17 mins 10 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... ##############################
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +44 C
External Temperature............................. +30 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 4
Number of Active Clients......................... 252
Burned-in MAC Address............................ ################################
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 500
System Nas-Id.................................... ################################ - Greyed our for Privacy
WLC MIC Certificate Types........................ SHA1
2. AP: sh version;
Cisco IOS Software, C1600 Software (AP1G2-K9W8-M), Version 15.3(3)JA5, RELEASE SOFTWARE (fc1)
ROM: Bootstrap program is C1600 boot loader
BOOTLDR: C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFTWARE (fc1)
###################### uptime is 1 day, 23 hours, 23 minutes
System image file is "flash:/ap1g2-k9w8-mx.153-3.JA5/ap1g2-k9w8-xx.153-3.JA5"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-CAP1602I-E-K9 (PowerPC) processor (revision B0) with 187382K/74672K bytes of memory.
Processor board ID ######################
PowerPC CPU at 533Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.0.121.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: ######################
Part Number : ######################
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : ######################
Top Assembly Part Number : ######################
Top Assembly Serial Number : ######################
Top Revision Number : A0
Product/Model Number : AIR-CAP1602I-E-K9
Configuration register is 0xF
BVES-17AP1>sh ip interface brief
Interface IP-Address OK? Method Status Prot ocol
BVI1 ########### YES DHCP up up
BVI2 unassigned YES unset up up
BVI3 unassigned YES unset up up
Dot11Radio0 unassigned NO unset up up
Dot11Radio0.1 unassigned YES unset up up
Dot11Radio0.18 unassigned YES unset up up
Dot11Radio0.19 unassigned YES unset up up
Dot11Radio1 unassigned NO unset up up
Dot11Radio1.1 unassigned YES unset up up
Dot11Radio1.18 unassigned YES unset up up
Dot11Radio1.19 unassigned YES unset up up
GigabitEthernet0 unassigned NO unset up up
GigabitEthernet0.@@@ unassigned YES unset up up
Virtual-WLAN0 unassigned NO unset up up
Virtual-WLAN0.1 unassigned NO unset up up
Virtual-WLAN0.2 unassigned NO unset up up
Virtual-WLAN0.3 unassigned NO unset up up
Virtual-WLAN0.4 unassigned NO unset up up
Virtual-WLAN0.5 unassigned NO unset up up
Virtual-WLAN0.6 unassigned NO unset up up
Virtual-WLAN0.7 unassigned NO unset up up
Virtual-WLAN0.8 unassigned NO unset up up
Virtual-WLAN0.9 unassigned NO unset up up
Virtual-WLAN0.10 unassigned NO unset up up
Virtual-WLAN0.11 unassigned NO unset up up
Virtual-WLAN0.12 unassigned NO unset up up
Virtual-WLAN0.13 unassigned NO unset up up
Virtual-WLAN0.14 unassigned NO unset up up
Virtual-WLAN0.15 unassigned NO unset up up
Virtual-WLAN0.16 unassigned NO unset up up
Fill in the details.  There is nothing "private" or "confidential" about this.
Besides making sure that the the regulatory domain settings match, also check if the "out-of-box" feature is enabled under the "RF Profiles" configuration which can be found under the "Wireless" tab of the WLC.
Hello Freerk,
"out-of-box" feature is not enabled on the WLC.
Configured Country............................... Multiple Countries:AT,BE,CH,CN ,CZ,DE,ES,FR,IT,PL,PT
Radio is disabled because PRoC (country code of "CN") is not compatible with European Regulatory Domain.  Disable "China" (and maybe a reboot of the controller) and the radio will work.
Please don't forget to rate our useful posts.
