11-13-2012 04:41 PM - edited 07-03-2021 11:02 PM
We have eighteen Cisco Aironet wireless access points (most of them are AIR-AP1231G-A-K9 with 12.3(2)JA2 IOS loaded) across our campus which people have weird issues with connecting.
Everywhere, people can associate and get an IP address without any issues. However, they cannot maintain a reliable connection to systems either on our network or off. They will get a web page to load and then it drops them out. In addition, they cannot connect back again for random intervals of time. To make this even more bizarre is that for random intervals they maintain a solid connection until it kicks people out again.
The vlan itself (60 in the configuration file below) works without issue as we have devices plugged in directly to the vlan via a hardwired port and they are stable.
Below is the configuration file. Any reason why we would have this issue?
Thank you for your time.
Christopher Koeber
version 12.3
no service pad
service password-encryption
hostname AP-6
enable secret {authentication information}
enable password {authentication information}
username Cisco password {authentication information}
username admin password {authentication information}
ip subnet-zero
ip domain name {Domain Information}
no aaa new-model
dot11 ssid (Secure) Staff/Faculty
vlan 70
authentication open
dot11 ssid Public
vlan 60
authentication open
guest-mode
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid Public
short-slot-time
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no cdp enable
interface Dot11Radio0.60
encapsulation dot1Q 60 native
no ip route-cache
no cdp enable
bridge-group 60
bridge-group 60 subscriber-loop-control
bridge-group 60 block-unknown-source
no bridge-group 60 source-learning
no bridge-group 60 unicast-flooding
bridge-group 60 spanning-disabled
interface Dot11Radio0.70
encapsulation dot1Q 70
no ip route-cache
no cdp enable
bridge-group 70
bridge-group 70 subscriber-loop-control
bridge-group 70 block-unknown-source
no bridge-group 70 source-learning
no bridge-group 70 unicast-flooding
bridge-group 70 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.60
ip address 10.60.255.6 255.255.0.0
no ip route-cache
bridge-group 60
interface FastEthernet0.70
ip address dhcp
no ip route-cache
bridge-group 70
interface BVI1
no ip route-cache
ip default-gateway 10.60.0.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
logging snmp-trap emergencies
logging snmp-trap alerts
logging snmp-trap critical
logging snmp-trap errors
logging snmp-trap warnings
line con 0
transport preferred all
transport output all
line vty 0 4
login local
transport input all
line vty 5 15
login
transport input all
end
11-27-2012 08:57 AM
Hi Christopher,
Couple of suggestions before moving forward:
1. I would first secure these WLANs with a least a pre-shared key if possible(WPA/WPA2). Let me know if you need information on how to do this.
2. Next, I would remove the 'short-slot-time' on the radio:
config terminal
interface do0
no short-slot-time
end
If your users continue to have issues, I would want more information on the types of clients in the environment as well as wireless adapter make/model/driver version.
