Access Point Tripod
chongch01
Visitor
Anyone can recommend a reseller for AP tripod for site survey purpose?
Example:
http://www.cisco.com/c/en/us/td/docs/wireless/technology/ap1000/deployment/guide/hah_apdg/dg10ic.html#wp1010425
I'm in Malaysia & I did send a few inquiries to oversea dealers & no reply from them so far
divanko
Level 2
Level 2
We use these for mobile access point deployments:
http://www.amazon.com/Eliminator-Lighting-Stands-Tri32-Accessory/dp/B000WKW8EY/ref=sr_1_1?ie=UTF8&qid=1430998850&sr=8-1&keywords=dj+tripod
You could also look at these:
http://www.amazon.com/Gemini-ST04-Speaker-Stand/dp/B004QG4WE4/ref=sr_1_3?ie=UTF8&qid=1430998850&sr=8-3&keywords=dj+tripod
Really any kind of DJ tripod stand should work.  You might have to get creative for mount points, etc. We used the mounting brackets for the access points and zip tied them to the tripod T section and then installed the access point into the access point bracket.  You might also be able to use a round hose clamp if you can find one thin enough.
Cheers!
