Access point will not boot - C9120AXI-E
bjorn.jensen
I have an AP that only flashes green, and will not boot correct. The boot stops at "Board ID (0-18):" What should I choose?
5jjjjR
▒▒▒▒▒RD DQ P
00000000001111111111222222222233333333334444444444555555555566666666667
01234567890123456789012345678901234567890123456789012345678901234567890
00 -------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++---------
01 -------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++---------
02 ---------++++++++++++++++++++++++++X++++++++++++++++++++++++++---------
03 ------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++----------
04 ------+++++++++++++++++++++++++++X++++++++++++++++++++++++++++---------
05 ------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++----------
06 ------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++----------
07 --------++++++++++++++++++++++++++X+++++++++++++++++++++++++++---------
08 ----++++++++++++++++++++++++++X+++++++++++++++++++++++++++-------------
09 -----++++++++++++++++++++++++++X+++++++++++++++++++++++++++------------
10 ------+++++++++++++++++++++++++X+++++++++++++++++++++++++--------------
11 ------+++++++++++++++++++++++++X++++++++++++++++++++++++++-------------
12 -----++++++++++++++++++++++++++X+++++++++++++++++++++++++++------------
13 ----++++++++++++++++++++++++++X+++++++++++++++++++++++++++-------------
14 ---+++++++++++++++++++++++++++X+++++++++++++++++++++++++++-------------
15 -----+++++++++++++++++++++++++X++++++++++++++++++++++++++--------------
Shmoo RD DQ N
00 -------+++++++++++++++++++++++++++X++++++++++++++++++++++++++++--------
01 ------+++++++++++++++++++++++++++X++++++++++++++++++++++++++++---------
02 --------++++++++++++++++++++++++++X++++++++++++++++++++++++++----------
04 -------++++++++++++++++++++++++++X+++++++++++++++++++++++++++----------
06 ------++++++++++++++++++++++++++X+++++++++++++++++++++++++++-----------
08 -----+++++++++++++++++++++++++++X+++++++++++++++++++++++++++-----------
09 ------++++++++++++++++++++++++++X++++++++++++++++++++++++++------------
10 ------++++++++++++++++++++++++++X+++++++++++++++++++++++++++-----------
11 ------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++----------
12 -----++++++++++++++++++++++++++++X++++++++++++++++++++++++++++---------
13 ------++++++++++++++++++++++++++X+++++++++++++++++++++++++++-----------
14 ---++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-----------
15 ------++++++++++++++++++++++++++X++++++++++++++++++++++++++------------
RD DQS adjustments :
BL0: Start: 0x3C Final: 0x3C
BL1: Start: 0x3C Final: 0x3C
Shmoo WR DQ
00 ----+++++++++++++++++++++++++++X+++++++++++++++++++++++++++------------
01 ---+++++++++++++++++++++++++++X+++++++++++++++++++++++++++-------------
02 ---++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-----------
03 --+++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------------
04 ---+++++++++++++++++++++++++++X++++++++++++++++++++++++++++------------
05 -----+++++++++++++++++++++++++++X+++++++++++++++++++++++++++-----------
06 -----++++++++++++++++++++++++++X++++++++++++++++++++++++++-------------
07 ---++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++----------
08 ----+++++++++++++++++++++++++++X++++++++++++++++++++++++++++-----------
09 ------+++++++++++++++++++++++++X++++++++++++++++++++++++++-------------
10 -----++++++++++++++++++++++++++X+++++++++++++++++++++++++++------------
11 ----+++++++++++++++++++++++++++X+++++++++++++++++++++++++++------------
12 --+++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------------
13 -----+++++++++++++++++++++++++++X++++++++++++++++++++++++++++----------
14 -+++++++++++++++++++++++++++X++++++++++++++++++++++++++++--------------
15 ----+++++++++++++++++++++++++++X++++++++++++++++++++++++++++-----------
Shmoo WR DM
WR DM
00 -++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++------------
01 --+++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------------
DDR test done successfully
CFE Version: 5
Verifying MASTER U-Boot...
Launching MASTER U-Boot version 0x0032 ...
____ _
/ ___|(_) ___ ___ ___
| | | |/ __| / __|/ _ \
| |___ | |\__ \| (__| (_) |
\____||_||___/ \___|\___/
_ _ ____ _
| | | | | __ ) ___ ___ | |_
| | | |___| _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
\___/ |____/ \___/ \___/ \__|
U-Boot 2017.09 (Oct 30 2019 - 19:23:10 -0700) Broadcom BCM49408
Board: VANC-i
I2C: ready
DRAM: 2 GiB
enable MMU ... OK
NAND: Status wait timeout: nandsts=0x0 mask=0x40000000, count=0
NAND ECC BCH-8, page size 4096 bytes, spare size used 216 bytes
1024 MiB
MMC:
SF: Detected mx25l6405d with page size 256 Bytes, erase size 4 KiB, total 8 MiB
In: serial
Out: serial
Err: serial
Platform: 4908
*** Board is not initialized properly ***
94908SV 0
94908DVT 1
94908DVT_SFPWAN 2
94908REF 3
94908REF_XPHY 4
94908REF_MOCA 5
94908REF_PLC 6
94906REF 7
94906REF_FAKE 8
94908REF_W2P5 9
962118REF 10
962116REF 11
949408EAP_XPHY 12
94908TBRHX 13
94908TBRHX_XPHY 14
94908TBRHX_W2P5 15
94906REF2 16
949408EAP_54991 17
VANC_54991 18
Board Id (0-18) :
Leo Laohoo
Contact Cisco TAC and organize for an RMA.
Leo Laohoo
