Accessing management console
sanjay.sangwan
Level 2
Level 2
Hi ,
I am not able to access the management console of BR-350 through IE- 6.0 using the IP address of the bridge in win2000 client workstation.I am facing the same problem in windows XP as well.However I am able to ping the bridge from both.But I got succeed using win98 and IE-6.0.Are there any issues with win 2000 and XP.My java properties are also enabled.
Sanjay
derwin
Level 10
Level 10
Hi Sanjay,
Log in via the console port ( serrial cable) There is a configuration option to disable web HTTP access
