Accounting in wireless controller
Zhomart Asken
Level 2
Level 2
Hi everyone!
I have the question according to accounting of wi-fi users. Does wireless controller support accounting of all connections, sessions(duration,mac, ip address etc) that were made during a predefined ammount of time, for example one month? If controller does not, how can I achieve this?
Best wishes, Zhomart
2 Accepted Solutions
Scott Fella
Nope... In order to have that information you would need Prime Infrastructure and an MSE which can store data. The WLC itself will not store all that information.
-Scott
manbaez
Level 3
Level 3
You could configur AAA inthe controller ( Chapter 6
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70.html
but, per say there is nothingfor that on the controller except the ones that are connected at that
particular time... You might want to have the full Boardless Network solution For Management
report. The BN solution will be WLC (Wireless LAN Controller) MSE (Mobility Service Engine)
annd PI (Prime Infrastructure) this will provide Management report on wireless devices and if
you go into release Connected Mobility Exxperience Flavor/Releases (WLC 7.4 - MSE 7.4 - PI
1.3) you could get even tracking and analitics info as well.
I hope this help with your answe... if any question or comments let me know
Thank you,
Manuel Baez
S E
8 Replies 8
Scott Fella
-Scott
manbaez
Level 3
Level 3
Thank you,
Manuel Baez
S E
In the Radius configuration part of the document you have provided it says following regarding to acconting functions:
"Accounting—The process of recording user actions and changes.
Whenever a user successfully executes an action, the RADIUS accounting server logs the changed attributes, the user ID of the person who made the change, the remote host where the user is logged in, the date and time when the command was executed, the authorization level of the user, and a description of the action performed and the values provided. If the RADIUS accounting server becomes unreachable, users are able to continue their sessions uninterrupted."
But can it gather the information about the connected devices, like it's type, mac-address, operating system etc? It would be very useful for security reasons to monitor the guest users, who don't have their own login. And if Radius can't do that, then would be your Boardless Network solution with MSE and Prime, proposed by you earlier, be the answer for our needs?
Zhomart Asken
Level 2
Level 2
Thanks for your advices! And if controller supports AAA could we use Radius server to gather this information from controller and store it there?
The WLC does support radius, but you would have to parse that information and also send that information to a syslog since the radius will not keep that much info. You would have to research how much data your radius server will keep before it will truncate the old data.
-Scott
Scott Fella
Maybe download PI and get an evaluation license so you can get a feel for what is does.
-Scott
Scott Fella
It will not know of the type of device. With that, you need ISE that can profile the device.
-Scott
Scott Fella
Let me explain this part.
You should use a proxy or some sort of connect filter. Without any login, you will not get much info about a user, but you will get Mac, IP, site visited, etc. the device type will only be discovers using ISE also. So ISE might be your answer along with maybe a content filter.
-Scott
