ACL blocking traffic towards the management interface on WLC 5508
Hello All,
I need to apply an ACL in WLC 5508 such that it would allow https traffic on management interface only from selected clients.
For same, I have created an ACL permitting only the intended users while blocking the rest. Have applied the same on the management interface.
However still the access from all devices to management interface is not blocked. The ACL hit count too is not incremented.
I am on WLC code 8.0.110.0.
Has anyone else faced similar issue while applying ACL against management interface.
Highly appreciate the inputs.
Thanks and Regards,
Adnan
Philip91
Hi Adnan,
you have to apply this ACL as a CPU ACL. Then it will work.
For your reference:
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/109669-secure-wlc.html#t4
Hope that helps...
Kind regards
Philip
--> Pls rate useful responses <--
