03-15-2011 08:49 AM - edited 07-03-2021 07:57 PM
I am trying to restrict guest users only to HTTP/HTTPS traffic, while my guest users are authenticating with internal Web Auth (LobbyAdmin)
When i am Appling following ACL configuration on Interface "GUEST-ACL" - Guest users are getting proper IP-->redirection Web login page--> Authenticated --> but page is not redirecting to requested page Ex: www.google.com
Am I missing any port or protocol in these ACL's, so that- after getting authenticated, page will redirect to desired page.. Please advice
Device info 4402, Codes 7.0.98.0, Web Auth Login- internal
ACL configuration
permit any IP/255.255.255.255 udp dhcp-c dhcp-s any Outbound
-allows any traffic to make a dhcp request
permit IP/255.255.255.255 any udp dhcp-s dhcp-c any Inbound
-allows the dhcp server to respond to the client request
permit any IP/255.255.255.255 tcp DNS any any any
-dns traffic to and from...
permit any any tcp http any any any
-allow http traffic anywhere
permit any any tcp https any any any
-allow https traffic anywhere
Solved! Go to Solution.
03-15-2011 08:56 AM
Irfanullah,
Try changing the DNS ACL from tcp to udp. TCP is used for zone transfers, which the guest shouldn't be doing in your network.
Cheers,
Steve
If this helps you and/or answers your question please mark the question as "answered" and/or rate it, so other users can easily find it.
03-15-2011 08:55 AM
Take the controller out of the equation for a second.
Have you tested the subnet itself to see if you can reach google.com?
What does your vlan interface configuration look like?
We have a similar setup. Our router is the DHCP server. We had to define the DNS server (used OpenDNS).
Can you share more of your config?
Ven
03-15-2011 08:56 AM
Irfanullah,
Cheers,
Steve
03-15-2011 09:14 AM
Thanks for reply..
I have tested DNS ACL to TCP & UDP both but it didn’t worked...any other suggestion
03-15-2011 09:26 AM
when you have connected to the guest network, prior to authenticating, try to do a nslookup www.kmart.com you should see something similar to :
Non-authoritative answer:
Address: 96.16.241.128
Aliases: www.kmart.com
www.kmart.com.edgekey.net
If you don't get a response, then it would seem that the dns resolution is not working correctly.
you can also test by going to http://74.125.225.18 and seeing if you get the redirect page, authenticate and then you should go to the website
Cheers,
Steve
03-15-2011 09:28 AM
Thanks ..I will try & let you know..soon
