ACL on flexconnect APs?
Daniel Parker
Community Member
I previously setup some access control list to block access to certain areas which was tested and worked fine.
Part of a Wi-Fi expansion project required me to switch over to Flex connect mode on the AP's to allow centralised management.
However since the change my ACLs no longer work. I attempted to setup a Flexconnect ACL but afterwards clients were unable to obtain IP's (FC ACL rules mirror my original ACL which worked fine)
any advise would be much appreciated.
Rasika Nayanajith
Hi Daniel,
Are you doing FlexConnect local switching ?
If so, best place to apply ACL is L3 SVI of brach switch for a given wireless user VLAN.
Rasika
**** Pls rate all useful responses ****
Rasika Nayanajith
Hi Daniel,
Rasika
