ACS 5.1 Auto PAC Provisioning - where is it?
Nigel Bowden
Level 2
Level 2
I see that auto PAC provisioning is discussed in the ACS 5.1 user guide, but I have serached the GUI, and I just can't find out how to turn auto provisioning on & off.
The user guide talks about the setting being under the global settings for EAP-FAST, which I've found, but there is no mention of auto provisioning. I can see how to manually create a PAC file etc., but no auto provisioning setting.
Anyone any idea where it is?
NIgel.
Jatin Katyal
Auto pac provisioning option is available under access-policies. Please go access-policies >> default network access > click on the tab "Allowed protocols" >> look at the bottom >> Check the option "Allow EAp-fast" and then expand it > here you can configure all the settings on a per access ploicu basis.
http://www.ciscosystems.cd/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.1/user/guide/eap_pap_phase.pdf
JK
Do rate helpful posts-
~Jatin
