ACS 5.2 EAP-TLS Machine Authentication
Roger Alderman
Level 5
Level 5
Hi All
I have set up an ACS (5.2) to do EAP-TLS Machine and User Authentication.
I am getting intermittent results with the machine authentication using the same laptop as a test client.
When the machine authentication succeeds the RADIUS name shows as host/xxx-yyy.
When the machine authentication fails the RADIUS name shows as xxx-yyy without the host/.
Anybody have any ideas why this is happening?
Roger
9 Replies 9
Scott Fella
When you are testing, are you rebooting the machine?
Scott Fella
Sent from my iPhone
-Scott
Hi Scott
I have rebooted the machine yes. However, you don't need to go that far. It's sufficient to simply log-off the user and the machine authentication will kick in again. That's standard practice.
Just wondering when it fails. When it is rebooted or when logging off and logging on.
Scott Fella
Sent from my iPhone
-Scott
Scott
It appears to be random.
It will fail and then a few minutes later it will pass.
The only discrepancy I can see is the RADIUS name but I don't see how this would change so it may be a red herring!
Roger
If your using windows 7, did you just specify computer, not user or computer.
Scott Fella
Sent from my iPhone
-Scott
It is Windows 7. We've specified 'computer or user' since we want to use machine and user authentication.
It's machine OR user not both.
Scott Fella
Sent from my iPhone
-Scott
What are you saying? That you can't have both machine and user EAP-TLS authentication?
This has always worked with XP and I've got it working with Windows 7 if I set the client to 'computer or user'.
It just seems to be a bit flaky on the machine authentication.
Roger
I was thinking you were ysing PEAP.  Well it seems like the issue is with the client not sending the host/ which ACS is looking for,
-Scott
