11-19-2012 09:35 AM - edited 07-03-2021 11:04 PM
Hi Netpro
I need to acheive the below
1)i need to setup a Cisco unified wireless network , i need to configure 802.1X Auth to my WiFi Users , we setup acs 5.3 as Radius connected to AD
can the 802.1X auth work without Certificate or its must , currently we dont have CA Server in my enterprise , if itsn't work can i use self cert on the acs it self?
2)on the acs access policy which protocol should i use TACACS+ or Radius?all dcs mentiond radius!
thanks
11-19-2012 08:06 PM
You can use a self signed certificate generated from ACS. You also must use radius not tacacs. Tacacs is for device management access not for user authentication.
11-19-2012 08:12 PM
This link should help you get started.
https://supportforums.cisco.com/docs/DOC-21679
